查看: 1511|回复: 0
FPGA 后仿真端口数量不对问题
    发表于 2024-8-28 21:39:09 | 显示全部楼层 |阅读模式
    FPGA 后仿真端口问题,输入Clk,Rst_n,a。输出b,c。前仿真没问题,后仿真出现问题不知道什么原因。
    • module dpram(
    •   Clk,
    •   Rst_n,
    •   a,
    •   b,
    •   c
    •   input Clk;
    •   input Rst_n;
    •   input a;
    •   output reg b;
    •   output reg c;
    • always@(posedge Clk)
    •    if(!Rst_n) begin
    •       b <= 1'b0;
    •       c <= 1'b0;
    •     end
    •     else begin
    •        b <= a;
    •         c <= b;
    •     end
    • endmodule
    • `timescale 1ns/1ns
    • `define clk_period 20
    • module dpram_tb();
    •     reg Clk;
    •     reg Rst_n;
    •     reg a;
    •    wire b;
    •     wire c;
    • dpram dpram(
    •    .Clk(Clk),
    •     .Rst_n(Rst_n),
    •     .a(a),
    •     .b(b),
    •     .c(c)
    •     initial Clk = 1;
    •     always#(`clk_period/2)Clk = ~Clk;
    •     initial begin
    •       Rst_n = 0;
    •       a = 1'b0;
    •       #(`clk_period*2);
    •       Rst_n = 1;
    •       #(`clk_period*2);
    •       repeat(20)begin
    •           a = 1'b1;
    •           #(`clk_period);
    •           a = 1'b0;
    •           #(`clk_period);
    •       end
    •       $stop;
    •     end
    • endmodule
    • ** Error: (vsim-3389) C:/Users/lipen/Desktop/dpram/prj/../testbench/dpram_tb.v(21): Port 'c' not found in the connected module (5th connection).
    • #         Region: /dpram_tb/dpram
    • # ** Fatal: (vsim-3365) C:/Users/lipen/Desktop/dpram/prj/../testbench/dpram_tb.v(21): Too many port connections. Expected 4, found 5.
    • #    Time: 0 ps  Iteration: 0  Instance: /dpram_tb/dpram File: dpram_8_1200mv_85c_slow.vo
    • # FATAL ERROR while loading design
    • # Error loading design
    GMT+8, 2025-9-4 00:22 , Processed in 0.048516 second(s), 27 queries .
