查看: 3318|回复: 0
【Zynq】vivado2019.1 sdk下载程序时报错的解决方案
发表于 2024-1-15 18:16:31 | 显示全部楼层 |阅读模式
如题,如果在Vivado2019.1的sdk中下载程序时,出现以下情况
warning: Can not parse XML target description; XNL support was disabled at compile time
warning: No executable has been specified and target does not support determining executable automatically.
Try using the "file" command.oxe08eee0efffce0ee in ??
这个是vivado2019.1的软件bug,xilinx官方给出了解决方案
可以参考Xilinx官方给的帖子,下载补丁
https://support.xilinx.com/s/article/72549?language=en_US
为了防止有的人下载失败,这里也直接给出补丁文件
SDK.7z (3.53 MB, 下载次数: 1706)
GMT+8, 2025-8-31 09:30 , Processed in 0.056345 second(s), 33 queries .
