查看: 13694|回复: 1
EDA扩展板-V1 资料
  • 20
    1529
    发表于 2019-9-7 11:59:35 | 显示全部楼层 |阅读模式
    这个小板我们前后做了两款,两款的功能管脚是一模一样的,程序兼容,无需修改引脚。以下为两款小板的原理图
    EDA小板原理图文件(绿色PCB 独立大拨码开关版本): EDA扩展板图纸.pdf (285.81 KB, 下载次数: 1623)
    EDA小板原理图文件(黑色PCB 8合1小拨码开关版本): EDA扩展板V1.01.pdf (123.07 KB, 下载次数: 1289)
    #EDA-V1扩展板接AC620开发板摄像头接口管脚约束脚本
    1. #EDA-V1扩展板接AC620开发板摄像头接口管脚约束脚本
    2. set_location_assignment PIN_L7 -to SW[0]
    3. set_location_assignment PIN_P3 -to SW[1]
    4. set_location_assignment PIN_N5 -to SW[2]
    5. set_location_assignment PIN_M2 -to SW[3]
    6. set_location_assignment PIN_N3 -to SW[4]
    7. set_location_assignment PIN_M6 -to SW[5]
    8. set_location_assignment PIN_R7 -to SW[6]
    9. set_location_assignment PIN_T2 -to SW[7]
    10. set_location_assignment PIN_P1 -to Led[0]
    11. set_location_assignment PIN_T7 -to Led[1]
    12. set_location_assignment PIN_K10 -to Led[2]
    13. set_location_assignment PIN_P8 -to Led[3]
    14. set_location_assignment PIN_M7 -to Led[4]
    15. set_location_assignment PIN_T6 -to Led[5]
    16. set_location_assignment PIN_N6 -to Led[6]
    17. set_location_assignment PIN_P6 -to Led[7]
    18. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[0]
    19. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[1]
    20. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[2]
    21. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[3]
    22. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[4]
    23. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[5]
    24. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[6]
    25. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[7]
    26. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[0]
    27. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[1]
    28. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[2]
    29. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[3]
    30. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[4]
    31. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[5]
    32. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[6]
    33. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[7]
    附加工程源代码:
    Traffic_lights.rar (34.62 KB, 下载次数: 1491)
    1.准备材料
    ac620开发板一块、eda扩展板一块
    2.实验效果图展示
    &#body;
    4
    发表于 2025-1-17 19:38:42 | 显示全部楼层
    没有对应管脚的表格了吗???我一直没找到,很不方便!!!
    GMT+8, 2026-1-25 14:27 , Processed in 0.053848 second(s), 38 queries .
