查看: 6765|回复: 0
fifo问题
  • 5
    发表于 2019-3-7 20:51:01 | 显示全部楼层 |阅读模式
    我向fifo里写了4个4位数,在读出来发现仿真没问题,signaltapII抓线时,却不对。代码如下:
    `timescale 1ns/1ns
    module fifo_test(
            Rst_n,
            mii_rx_clk,
            mii_tx_clk,
            WKC
    input Rst_n;
    input mii_rx_clk;
    input mii_tx_clk;
    output reg[15:0]WKC;
    wire tx_go;
    reg[3:0]fifo_wrdata;
    reg fifo_wrreq;
    wire fifo_wrclk;
    wire[10:0]fifo_wruse;
    wire[3:0]fifo_rddata;
    reg fifo_rdreq;
    wire fifo_rdclk;
    wire rdempty;
    wire[10:0]fifo_rduse;
    assign fifo_wrclk=mii_rx_clk;
    assign fifo_rdclk=mii_tx_clk;
    Rx_fifo Rx_fifo(
            .aclr(!Rst_n),
            .data(fifo_wrdata),
            .rdclk(fifo_rdclk),
            .rdreq(fifo_rdreq),
            .wrclk(fifo_wrclk),
            .wrreq(fifo_wrreq),
            .q(fifo_rddata),
            .rdempty(rdempty),
            .rdusedw(fifo_rduse),
            .wrfull(),
            .wrusedw(fifo_wruse)
    //fifo里存放4个4位数
    reg[2:0]cnt;
    reg flag;
    always@(posedge mii_rx_clk or negedge Rst_n)
    if(!Rst_n)begin
            fifo_wrreq<=#1 0;
            fifo_wrdata<=#1 0;
            cnt<=#1 0;
            flag<=#1 0;
    else if(tx_go)begin
            cnt<=#1 5;
    else if(cnt>=2)begin
            fifo_wrreq<=#1 1;
            fifo_wrdata<=#1 (fifo_wrdata+1'b1);
            cnt<=#1 cnt-1'b1;
    else if(cnt==1)begin
            fifo_wrdata<=#1 0;
            fifo_wrreq<=#1 0;
            flag<=#1 1;
            cnt<=#1 cnt-1'b1;
    else begin
            cnt<=#1 0;
            flag<=#1 0;
    //fifo里取出4个4位数
    reg[7:0]flag_dly;
    if(!Rst_n)
            flag_dly<=#1 0;
    else
            flag_dly<=#1 {flag_dly[6:0],flag};
    reg[2:0]data_cnt;
    always@(posedge mii_tx_clk or negedge Rst_n)
    if(!Rst_n)begin
            fifo_rdreq<=#1 0;
            data_cnt<=#1 0;
            WKC<=#1 0;
    else if(flag_dly[7])begin
            data_cnt<=#1 4;
            fifo_rdreq<=#1 1;
    else if(data_cnt>=2)begin
            fifo_rdreq<=#1 1;
            WKC<=#1 {WKC[11:0],fifo_rddata};
            data_cnt<=#1 data_cnt-1'b1;
    else if(data_cnt==1)begin
            fifo_rdreq<=#1 0;
    else begin
            data_cnt<=#1 0;
    reg [8:0]counter;
    if(!Rst_n)
            counter <=#1  0;
    else //计数器自增,不考虑溢出,接受溢出自动清零
            counter <=#1  counter + 1'b1;
    //每671ms(该值无特殊要求,这里取计数器自溢出,接近0.5ms发送一次数据的目的)启动一次发送数据
    assign tx_go =  (counter == 9'd1);
    http://file:///d:\\Documents\\Tencent Files\\2579622230\\Image\\C2C\\7NX42$0D)NHU()W0KL__557.png
    http://file:///d:\\Documents\\Tencent Files\\2579622230\\Image\\C2C\\]A8Q`K)Q$HI$ZW)2``F7D2Q.png
    GMT+8, 2025-9-18 16:29 , Processed in 0.049833 second(s), 26 queries .
