查看: 32236|回复: 2
Quartus一直提示没安装device,安装了也不行。 You successfully i...
  • 442
    发表于 2018-5-26 18:32:08 | 显示全部楼层 |阅读模式
    You successfully installed the Quartus II software, but did not install any devices. Do you want to launch the device installer to add devices。
    Description
    Due to a problem in the Quartus® II software version 13.0, you may see the following message during installation if your license is not valid or no longer under maintenance.
    Workaround/Fix
    To avoid this problem, use the valid license file that is currently under maintenance.
    The message has been updated beginning with version 13.1 of the Quartus II software.
    原文链接:
    https://www.altera.com/support/support-resources/knowledge-base/solutions/rd07282013_809.html
    欢迎二楼出中文译本
    解决方法:
    第一步,删除已经安装的器件库,具体操作方法如下所示
    第二步:重新安装器件库
    第三步:重新破解quartus软件
    发表于 2018-5-26 18:41:02 | 显示全部楼层
    中英对照:
    您已经成功地安装了Quartus II软件,但您并没有安装任何设备(指 ALTERA 的FPGA 如Cyclone IV)。您想启动设备安装程序来添加设备吗?
    Description
    描述
    由于Quartus ® II软件13.0版本的问题,如果您的许可证无效或不再维护中,您可能会在安装中看到如下消息:
    “You successfully installed the Quartus II software, but did not install any devices. Do you want to launch the device installer to add devices”
    Workaround/Fix
    解决方法
    为了避免此类问题的发生,请使用目前正在维护的有效的许可证文件
    该消息在Quartus II软件的13.1版本中已经更新。(13.1及之后的软件不会出现)
    2021-10-8 21:08
    发表于 2018-9-4 14:18:27 | 显示全部楼层
    原来是这么个情况啊,我说怎么重新破解一次就好了呢………………
    GMT+8, 2025-9-8 07:43 , Processed in 0.047779 second(s), 30 queries .
