查看: 333|回复: 2
sof2flash: Unrecognized device family in SOF
  • 283
    发表于 2021-9-6 20:52:29 | 显示全部楼层 |阅读模式
    Type: Answers
    Type: How-To
    Area: Embedded
    Last Modified: April 19, 2018
    Version Found: v17.1
    Bug ID: FB: 553632;
    Why does the sof2flash utility fail to work with EPCQ device in Intel® Arria® 10, Intel® Cyclone® 10 and Intel® Stratix® 10 designs?
    Description
    Due to a problem in the Intel® Quartus® Prime Design Software version 17.1 and earlier, the sof2flash utility may fail to work with EPCQ device in Intel® Arria® 10, Intel® Cyclone® 10 and Intel® Stratix® 10 designs.
    The following error message may be seen:
    Workaround/Fix
    To work around this problem, follow the steps below:
    • Generate RPD via Convert Programming Files tool
    quartus_cpf -c --device=<EPCQ flash density> -o auto_create_rpd=on -o rpd_little_endian=off <SOF filename> <POF filename>
    Example: quartus_cpf -c --device=EPCQ64 -o auto_create_rpd=on -o rpd_little_endian=off c10lp_gsrd.sof c10lp_gsrd.pof
    • Convert RPD to .flash via nios2-elf-objcopy tool
    nios2-elf-objcopy -I binary -O srec --srec-forceS3 --srec-len 32 <RPD filename> <FLASH filename>
    Example: nios2-elf-objcopy -I binary -O srec --srec-forceS3 --srec-len 32 c10lp_gsrd_auto.rpd c10lp_gsrd.flash
    This problem is scheduled to be fixed in a future version of the Intel® Quartus® Prime Design Software.
    https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2018/why-does-the-sof2flash-utility-fail-to-work-with-intel--arria--1.html?wapkw=sof2flash%3A%20%22Unrecognized%22%20device%20family%20in%20SOF
  • 283
     楼主| 发表于 2021-9-7 12:07:28 | 显示全部楼层
    cyclone10使用EPCQ进行boot,可以参考现在都是按照Embedded Design Handbook中5.2.3. Nios II Processor Booting from EPCQ Flash说的合并为jic的方法做。
    edh_ed_handbook.rar (8.3 MB, 下载次数: 27)
  • 283
     楼主| 发表于 2021-9-7 13:58:14 | 显示全部楼层
    n2sw_nii5v2gen2.pdf (3.48 MB, 下载次数: 26)
    GMT+8, 2021-10-22 14:12 , Processed in 0.066342 second(s), 11 queries , File On.
