查看: 885|回复: 0
12002 Port "byteenable2" does not exist in macrofunction "...
  • 136
    发表于 2018-6-21 14:50:36 | 显示全部楼层 |阅读模式
    在NIOS 中使用双口RAM报错12002 Port "byteenable2" does not exist in macrofunction "xxx"。
    这是Quartus 13.0软件的bug。在altera官方网站上有解决指导方案。官网的说明路径就不贴了,过两个月altera域名就无法访问了,整合到Intel中了。直接把官网的原文发出来。
    Type: Answers
    Area: Tools
    Last Modified: October 21, 2013
    Version Found: v13.0
    Version Fixed: v13.0 Service Pack 1
    Error (12002): Port "byteenable2" does not exist in macrofunction "onchip_memory<instance>"Description
    Due to a problem in the Quartus® II software version 13.0, the dual port RAM (on-chip memory) component in Qsys incorrectly adds the signal byteenable2on slave s2 when the data width is set as 8 bits.
    Workaround/Fix
    To work around this problem, perform the following steps:
    • Open the file altera_avalon_onchip_memory<instance>_hw.tcl in a text editor and comment line 671.
      #add_interface_port s2 byteenable2 byteenable Input
    • Add the following lines under line 671:
      if { > 1} {
    • Refresh and regenerate the system
    This problem is fixed beginning with the Quartus II software version 13.0 SP1.
    意思很简单,学fpga的应该都能看得懂这个。不懂的请热心二楼来翻译吧。
    直接改文件就行了,如果不会改,直接下载附件提供的文件,替换下你软件中对应文件即可。比如我的电脑是D:\altera\13.0\ip\altera\sopc_builder_ip\altera_avalon_onchip_memory2
    altera_avalon_onchip_memory2_hw.tcl (38.57 KB, 下载次数: 17)
  • 29
    发表于 2018-6-21 19:25:46 | 显示全部楼层
    好文章,赞一个!
    *滑动验证:
    GMT+8, 2019-2-22 07:41 , Processed in 0.101239 second(s), 11 queries , File On.
